| Home > Help Needed / General Tech Chat > no spark with megasquirt | |||||||
![]() 1128 Posts Member #: 142 Post Whore Winchester |
3rd Sep, 2006 at 09:21:43pm
hi guys, long time no posts!
3rd Sep, 2006 at 09:30:14pm
coil pack wiring....
AlexF |
3rd Sep, 2006 at 09:45:43pm
You can test the crank sensor as follows, connect a multimeter to the pins, set the multimeter to "AC VOLTS".
567 Posts Member #: 102 Post Whore Pennsylvania USA |
4th Sep, 2006 at 01:26:33am
Make sure you have good grounds aswell, thats what my problem was. |
4th Sep, 2006 at 08:52:32pm
forget the mj for now. it should run just on the edis itll set the timing to 10 degrees (fail safe mode). get it running on the edis then inroduce the jolt.
4th Sep, 2006 at 09:26:44pm
cheers for the advise guys i'll have a good check over and report back
6th Sep, 2006 at 08:24:36pm
hi guys, still stuck!
6th Sep, 2006 at 08:58:24pm
As has already been mentioned you can ignore the pip and saw until you connect the MS. The car will run with just the EDIS, timing sensor and coil pack. If it is not and you are sure that the wiring is correct then something is broken. I have only had one EDIS fail on me (and I have had about 20 from scrap yards) but it does happen. http://www.twin-turbo.co.uk
6th Sep, 2006 at 09:10:23pm
The PIP and SAW wires are just for signal. It will run without those been connected. |
6th Sep, 2006 at 10:46:32pm
start again.
6th Sep, 2006 at 10:49:24pm
thanks for the advise guys, i'll give it a go and see what happens
6th Sep, 2006 at 10:50:07pm
Have you checked out the crank sensor as I explained above? This is the basic starting point as without this nothing will work.
6th Sep, 2006 at 10:57:24pm
i can't as i don't have a spare dizzy to hand unfortunatley.
8th Sep, 2006 at 04:25:44pm
got an update now, yesterday i hooked up the power to coil pack and ignition module which i had forgotten to do !!!
8th Sep, 2006 at 05:42:39pm
plug leads on the wrong plugs ?? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
8th Sep, 2006 at 07:24:50pm
sounds like timings out. 10 degrees should be fine to start your engine.
Edited by Carl on 8th Sep, 2006. no longer a series, but still 1.3 turbo.
8th Sep, 2006 at 11:06:38pm
thats plug leads round the wrong way! AlexF |
8th Sep, 2006 at 11:09:09pm
i have 1 @ rad end and 4 @ clutch end, i will swap them round just on thee off chance lol!
Edited by clubman_dan on 8th Sep, 2006. |
9th Sep, 2006 at 10:05:01am
9th Sep, 2006 at 11:35:47am
good picture dan ,um if its wasted spark arent 1 and 4 fired at the same time ,and same with 2 and 3 ,so if the leads were on the wrong plugs it 'd have to be moved from 1 and 4 to 2 and 3 ..( warning i do not have my thinking head on ) Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
9th Sep, 2006 at 03:14:30pm
The sensor need to be 90 degrees before TDC *if* the missing tooth is at TDC.
AlexF |
9th Sep, 2006 at 11:58:37pm
i have an update, and its good news!!
