| Home > Help Needed / General Tech Chat > Upping the boost | |||||||
103 Posts Member #: 31 62horses at the wheels and counting |
18th Apr, 2004 at 10:06:59pm
Following the RR I am looking to up my boost from it's very standard 4/5PSI. |
141 Posts Member #: 162 Advanced Member |
18th Apr, 2004 at 10:52:03pm
right ditch the ecu if you are using one, then turn up the bleed valve |
19th Apr, 2004 at 07:46:04pm
cordantium speak to iain before you mess with your boost because im sure he said yours was overboosting so you might be better getting a new actuator i use an incar boost adjuster then you can adjust it when you feel like it or turn it down when its pinking on the rolling road no longer a series, but still 1.3 turbo.
20th Apr, 2004 at 01:37:02pm
Yep, watch the gauge mate, you can see it overboost and sit back.
Forum Mod 1140 Posts Member #: 93 Post Whore Near Lincoln |
20th Apr, 2004 at 02:19:57pm
Certainly sounds as though the actuator is lifting off when you start boosting, quite a few turbo cars tend to do this anyway. A stronger actuator sounds like a good idea to me.
20th Apr, 2004 at 03:38:38pm
montego's fit i think, 10psi IIRC
