Home > Help Needed / General Tech Chat > understanding a carb
1976_mini
Member #: 259
grays, essex
having a bit of trouble understanding the carb lads, hope you can help. I understand the petrol in and the pressure sensing hose to the ecu and fpr but what is the other pipe for thats next to the main feed in? Ive put a picture up and put a question mark in the box. The manual says its the float chamber venting valve (wen fitted), someone else told me its the anti run on valve. Either way its blocked off and i dont no wether it should be or not!
it may b small but it purfectly formed
http://photobucket.com/albums/v340/1976_mi...roject%20turbo/
Dangerous
Member #: 417
That be the anti run on valve,just block it up like it is
1976_mini
Member #: 259
grays, essex
thanks dangerous, i can sleep tonight now *happy*.
Dangerous
Member #: 417
here ya go
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=6298
Not quite the anti run on valve that one, it was used on the Metro as a float chamber vent valve, that vented the float chamber when the car was switched off.
But as Brian says, block it up, make sure it is air tight too!
1976_mini
Member #: 259
grays, essex
superb brian, just what i needed and tom, thanks mate.
Dangerous
Member #: 417
unless you do the "turbo dave T piece trick"then you T it in to the pressure hose
Worked wonders for me *wink*
1976_mini
Member #: 259
grays, essex
i shall try it all tomorrow, got to re-build the carb 1st
