Home > Help Needed / General Tech Chat > material exhaust manifold
beestje007
Member #: 1230
hello, im going to weld a new exhaust manifold, which material should i use, because its getting very hot.?? thanks
Steel
beestje007
Member #: 1230
just steel, no special steel? what temps does a nicely turbotuned 1275 engine get? There are also exhaust manifolds that shine so nice, with a bleu red shine from the heat? is that also steel?
Edited by beestje007 on 5th Sep, 2006.
304 Greade stainless as a minimum.
321 grade stainless is the ultimate in a reliable long-lasting manifold for a turbocharged engine. This is what was specc'd out on Jims manifold.
Quality doesn't come cheap however. This is amongst the most expensive stainless tubing to purchase.
as dave said, I made mine from 321 Stainless.
i love 321, its free from work *happy*
