Home > Help Needed / General Tech Chat > Bleed valve
Supereds
Member #: 1244
Bagshot, Surrey
Can anyone recommend the best type of in car adjustable bleed valve or alternatively a presssure regulator so i can increase the boost from the 4psi it's currently running.
Any links welcome so i can take a look.
Ric
Member #: 36
Basingstoke
worth having a seach, it's been covered tons of times.
Basically, put a t piece in the hose that goes from your compressor housing to the actuator and run a bit of hose from it to a bleed valve *preferably lockable* Then set how much boost you want to run with a boost gauge on a run.
A search will explain better than i have though.
If you don't want all the boost to come on in one big lump, might be worth playing with actuator preload settings. But don't know anything about doing that, so do some proper research first.
