Home > Help Needed / General Tech Chat > ARP ROD BOLTS ???
I obtained from miniits ARP rod bolts I asked for A+
It states that the suite A series and B series engines on the packet
The diameter and length are the same
IS……. there a set for the A+ specific ???
Dangerous
Member #: 417
On here it says a+,then when you click on the line it shows a picture of a and b
http://www.aptfast.com/APT_Parts/Aseries_P...a_Fasteners.htm
They only have 11/32 or 3/8
daniel_johno
Member #: 751
Aberdeen
im looking at my set for my turbo block (if i ever get it back from morspeed) and it just says A & B series 11/32" on the packet (part No 206-6002)
i ordered mine direct from Kent Cams and asked for A+ ones so i think its a one set does all sort of affair.
Dan
thats setled then gents i have the same
thanks
Richie
Member #: 628
iam sure the heads on the bolts were different from A to A+ ? i must be having an anurism or summat there wouldbe a clear choice from ARP if this was the case so i must be going nuts .......at least you are sortid now Steve. Did they put in a sachet of lube for u, or do you needs me to bring some down ?
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
