Home > Help Needed / General Tech Chat > dump valve ?
pauls 72 turbo
Member #: 1250
wrexham
first cheers turbo phil that did the trick running sweet now. as for my next querie when purchased turbo motor came with modified plenumb chamber was going to blank off but friend gave me a dump valve so connected it to pipe on plenumb now i do not know what the little pipe on the other end does or where it goes
any ideas would be gratefull
paul
the small pipe goes to the inlet manifold, ie after the throttle,
the function is when the throttle is closed the depression in the inlet manifold will suck open the dumpvalve, this will provide an escape for the pressurised air which is now obstructed bu the closed throttle.
pauls 72 turbo
Member #: 1250
wrexham
does this meam tapping a small outlet into the inlet manifold
Dangerous
Member #: 417
Thats what I did,well drilled and press fit just behind the servo take off
Dangerous
Member #: 417
Yellow pipe for wastegate,small pipe on top of servo for boost gauge
mmmmmmm carbon fibre....
JT
Member #: 637
Hertfordshire
is that a forge dump valve in the pick?
iv got one that looks the same suposedly a forge one.
is it loud or quiet?
cheers
josh
My build thread..
beestje007
Member #: 1230
i don't understand the things your saying here, because basicly this yellow thing isnt there? do u need it?
""" the small pipe goes to the inlet manifold, ie after the throttle,
the function is when the throttle is closed the depression in the inlet manifold will suck open the dumpvalve, this will provide an escape for the pressurised air which is now obstructed bu the closed throttle. """
yes
exactley as dangerouse has it
forget about the yellow pipe that dangorous has in the pic as its for the WASTGATE pressure side to open
