Home > Technical Chat > Urgent Rubber Spring info
not that anyone on here would probably use copys but worth knowing.
http://www.minimania.com/msgthread.cfm?Inf...4&StartReturn=1
got a news letter from minisport and it occured that they may be trying to off load dodgey cones cheap.
http://www.minisport.com/classic-mini-shop...es-product.html
Turbo Tel
Member #: 588
Delaware, USA
I bought some from Minisport 6 months ago, What they have there is a batch of cones that have the nuts welded in slightly off center, No problem for the rear as you don't use a compressor so they are unloading them as "rear cones" Otherwise they are exactly the same as the front , markings and all. I can't remember the markings but they looked good to me (Moulton??)
Edited by Turbo Tel on 27th Oct, 2006.
Turbo Tel
Member #: 588
Delaware, USA
What they have there is a batch of cones that have the nuts welded in slightly off center, No problem for the rear as you don't use a compressor so they are unloading them as "rear cones" Otherwise they are exactly the same, markings and all.
ahhh right,
I saw them on offer and the dodgey sinking ones sprang to mind.
I'm almost tempted to get some and tack a new nut in....
