| Home > Help Needed / General Tech Chat > ECU + BLEED | |||||||
![]() 826 Posts Member #: 247 Post Whore Kent/Surrey Borders |
20th Apr, 2004 at 12:43:50am
Chaps TurboLessTosser |
20th Apr, 2004 at 01:01:07am
You don't realy want to go disconnecting pipes to see what happens, the ecu can dissconnected by pulling the wires from the brass bitty i am sure.
20th Apr, 2004 at 01:11:11am
Thanx for your reply !!!
TurboLessTosser |
20th Apr, 2004 at 03:26:58am
uhm, isnt venting that pipe to atmosphere like running with a bleed nipple full open? i.e. as much boost as teh turbo wil push through the engine i.e. craploads more than 7psi? turbo 16v k-series 11.9@118.9 :)
20th Apr, 2004 at 09:50:11am
Yep it is!! Dont run with it open!!!
141 Posts Member #: 162 Advanced Member |
20th Apr, 2004 at 10:27:47am
hi guys im building a turbo unit also, and i am still not sure wat to do with the pipe from the t piece under the actuator, i believe this is for the ecu. so i have taken the ecu off wat do i do with the pipe do i block it off or can i fit my bleed valve to it. please help. |
