Home > Help Needed / General Tech Chat > 10psi needle thickness
Dangerous
Member #: 417
Any one got any ballpark figures for a 10psi needle (dia v length)
Having access to a cnc grinding machine I'm thinking of modding my own to suit the lamda reading
i have a brand new one here
Really don't think it's that simple mate, Jon F and I where running very simular boost levels back in 2004, his needle was like mig wire, very thin, mine was a standard thickness bdd, all very odd!
depends a lot on the spring .
the easy way it to pop it into a pillar dill bri and spin it up use P400 wet and dry and profile it where you want
CNC ?? not needed are you going to turn many out ?
Dangerous
Member #: 417
Hope not,but if I get it too small(rich) I can always coat it and redo again.
Can check the profile on a shadowgraph at 25xmag
fookig heck bri last time i worked with a shadow graph
was a rolls royce mount sorral Leicestershire 1993
go for it
Dangerous
Member #: 417
10 psi V std bdd
starting at shoulder
0 2.48 2.48 (0)
5 2.37 2.37 (0)
10 2.21 2.24 (.03)
15 1.92 2.03 (.11)
20 1.76 1.86 (.10)
25 1.62 1.75 (.13)
30 1.54 1.65 (.12)
35 1.45 1.58 (.13)
40 1.36 1.51 (.15)
45 1.31 1.46 (.15)
tip 1.28 1.43 (.15)
So the standard 10psi avonbar needle is approx .004" thinner in the middle and .006" at the pointy end
Edited by Dangerous on 14th Sep, 2006.
On 14/09/2006 10:34:51 Dangerous said:
So the standard 10psi avonbar needle is thinner in the middle and at the pointy end
now thats the sort of tech stuff i understand
LOL *smiley*
