Home > General Chat > quicky - standard (uk) steel sheet thickness?
I'm doing some files for Jimster to get laser-cut, but need to know what is the most common thickness around 3mm?
Is steel still being measured in swg, or is it generally metricified nowadays?
10 gauge is 3.25mm.....this is probably the closest commonly available to 3mm, most places I have dealt with generally work in swg still.
clubminiflip
Member #: 54
nr coventry
depending what the steel sheet is used for, bodypanels are between from 16swg-24swg depending on age & manufactuer
Cheers tom / flippy....
Sounds like SWG is still the preffered option...
clubminiflip
Member #: 54
nr coventry
cant beat the old measurements, ft,inches,ftlbs,bhp,swg,cm,10ths etc etc :oP
oh yes you can!
As I continully tell my fellow designers; The inch is all well and good - but it's around 25.4 times too large for any use :)
clubminiflip
Member #: 54
nr coventry
:oP haha thats top i love it, thats my new blaggin line! none of mine work anyway :oP
that must mean my nobs 25.4 times too big
thanks guys, thanks dave!
Leonard
Member #: 806
Cirencester, Gloucestershire
i work in fabrication and we regularly use and ask for 3mm sheet.
