| Home > Help Needed / General Tech Chat > hi,new member needing help | |||||||
![]() 213 Posts Member #: 249 Senior Member |
20th Apr, 2004 at 07:59:00pm
hi all,im new here and need a bit of help |
20th Apr, 2004 at 09:14:31pm
idler gear bearing at a guess. does it stop when you press the clutch pedal? Fairly common, needs a new bush, hopefully no damage to the crank. |
20th Apr, 2004 at 09:40:09pm
cheers iain,it doesnt stop when you press clutch but seems to get a little quieter...is it a big job to sort out?
21st Apr, 2004 at 02:22:33pm
Not something ive had to do to be honest. Im assuming its an engine in job but much easier with the engine out like most things! All depends how easy the clutch is to get off! |
21st Apr, 2004 at 07:18:46pm
also, check it isnt the timing chain? I had this on my 998 and thought the same thing, see if its coming from the casing. Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
21st Apr, 2004 at 08:31:02pm
could be a lose flywheel? mine was lose with that sort of noise. from what i can remember was the flange on the flywhee, which is held on with about 6-8 1/2 inch bolts theyed all come lose when i took the end cover off i cud move the flywheel abit clockwise and anticlockwise just an idea mate hope you get it sorted no longer a series, but still 1.3 turbo.
just got myself a mini and havent owned one for a few years,so have forgoten lots....when the car is idling and driving there is a grating,knocking noise from the offside engine area...the only way i can describe it is like a loose gear in a gearbox...i seem to remember this was common on minis and was the idler or drop gears??????? can anyone help :cool:
