| Home > Help Needed / General Tech Chat > Help with a Pre Verto Clutch problem | |||||||
16th Sep, 2006 at 08:48:49pm
The pre verto clutch on the 1275 GT is, well, lets say, odd!
16th Sep, 2006 at 08:59:24pm
I think the tread the pipe fits too is different between the two(pre verto unf/verto fine metric??)
17th Sep, 2006 at 10:10:03am
Firstley the pressure plate is Goosed! this is causing the extended arm your mate bodged up
17th Sep, 2006 at 05:17:12pm
The drive straps don't make a huge amount of difference - but basically they should be either level, or just under level (backplate end lower than the flywheel end when the flywheel is sat on the bench) such that when the friction plate wears by the smallest amount they're then sitting level.
On 16/09/2006 20:48:49 Mini Sprocket said:
Why are the bolts catching the wok in the first place with no throwout whatso ever? Edited by turbodave16v on 17th Sep, 2006. On 17th Nov, 2014 Tom Fenton said:
