Home > Help Needed / General Tech Chat > Lambda voltage
Dangerous
Member #: 417
Just fitted a sensor this morning(top fork nut of a kawasaki fit's a treat)
Wired it up to a multimeter as I have no gauge yet.
I'm getting .50 to .75 volts out of it(after a couple of miles drive to make sure its hot) so I take it that is a bit rich
Think it should be .45 can anyone confirm*oh well*
Forgot to mention my sensor is from a rover 620? out of the elbow on a t25 it's a bosch 4 wire
Edited by Dangerous on 17th Sep, 2006.
There's a link here to a graph.
I'd say you were running about right. You want to see about 0.1 to 0.3 under WOT.
EDIT: I'm wrong - should be 0.8 as evo said.
Edited by Paul S on 17th Sep, 2006.
evolotion
Member #: 83
Glasgow, Scotland
no, you want to see around .8v under WOT *wink*
Denis O'Brien.
Dangerous
Member #: 417
Well thats 2 opinions
I turned the mixture half turn weaker and now get
.4 idle
.5/.6 normal driving
.7 flatout up hill
0/.2 no throttle down hill
This is with a std bdd needle so I take it I don't need to fit the 10psi one,as that will make it richer
Do I need to go for the heavy spring or thicker oil
Dangerous
Member #: 417
Aha I see
wideband sensor more voltage=leaner
narrowband more voltage=richer
mines a narrow so about right till R/R time
Dangerous
Member #: 417
Found the info now guys
AIR/FUEL RATIO
GAUGE READING
14.7/1 0.50v
14.6/1 0.60v
14.5/1 0.70v
14.2/1 0.80v
13.5/1 0.85v
13.2/1 0.90v
13.0/1 0.92v
12.5/1 0.94v
12.0/1 0.95v
Happy turbocharged engine likes to be above 0.92v under the load.
wheres the rest of it? theres nowt below Stoich!!!!
narrowband sensors are accurate at 14.7:1
Thats as good as they get. If you are using them as a tuning tool, be very very aware that they are very innaccurate anywhere else.
their response is very non-linear, making it very difficult to use them reliably.
So tread with caution, or be sensible and buy a wideband.
Circa 0.9v should be ok on boost, but given they arent accurate/repeatable up there, its still not 100% safe.
Dont know where Dangerous got those readings, but they dont sound right to me.
Dangerous
Member #: 417
Found them here
http://www.zeitronix.com/questions/O2questions.htm
By their comparison, 0.94v = 13.0:1...
To suggest a turbo engine will be happy around that, isnt quite true.
A turbo engine will melt pistons at 13.0:1 It is far too lean to even think about using.
That said, their voltage shouldnt be far off, I totally disagree with their suggested AFR's to match the voltage.
But pressure and sensor temp does affect the output voltage by quite a bit.
Buy a wideband.
13.0:1 is rich though???
Dangerous
Member #: 417
thats what I thought
Up to you.
I would never run a turbocharged engine at an accurately measured 13.0:1 AFR
I may just tempt fate at 12.0:1, but even that is pushing it a little for safety.
11.5:1 for me.
If it was normally aspirated, then 13.0:1 would be fine.
