| Home > Technical Chat > Bushing S rods | |||||||
19th Sep, 2006 at 01:19:23pm
Has anyone bushed the small end of S rods to make them shorter?
19th Sep, 2006 at 03:02:45pm
i wouldn't try making offset bushes and then pressing them in, they could end up all in different places, you wouls need to press a solid bush in then set it up an a jig and bore it to siut ,that way all 4 rods go on the same jig, using the big end as you datum for length.
19th Sep, 2006 at 03:06:51pm
now that ive read you post properly,lol
19th Sep, 2006 at 03:13:00pm
I hadn't thought that far ahead as its just an idea but thats good advice.
Edited by Joe C on 19th Sep, 2006. On 28th Aug, 2011 Kean said:
19th Sep, 2006 at 05:37:26pm
Are you sure the 84mm is not actualy 84.33mm (81.33 +3 =84.33)
19th Sep, 2006 at 06:25:05pm
ah, yes it may be 84.33, I thought the most you could offset grind to was 84, but apparently not after checking,
