| Home > Help Needed / General Tech Chat > Twin Bleed Valve set up???? | |||||||
103 Posts Member #: 31 62horses at the wheels and counting |
20th Apr, 2004 at 10:06:40pm
Thinking. |
20th Apr, 2004 at 10:27:16pm
I think its well worth it. Obviously the minimum it can be set to is fully closed then its whatever your actuator is set at.
20th Apr, 2004 at 10:49:23pm
How can you set the boost without having the car on the road.
20th Apr, 2004 at 10:50:06pm
What is a good location for an in car boost valve??? |
![]() 439 Posts Member #: 176 Pre-op Transvestite Felixstowe, Suffolk |
20th Apr, 2004 at 11:21:54pm
on the dash :p NO LONGER A <3 lover of BOLT-ON plastic <3 .... (and DOUBLE proud of it) |
20th Apr, 2004 at 11:46:18pm
A little tip save your money with buying just one bleed valve..
21st Apr, 2004 at 12:42:12am
sounds good to me, not that i'm up with the technical side of things ... i just like the idea of saving money NO LONGER A <3 lover of BOLT-ON plastic <3 .... (and DOUBLE proud of it) |
21st Apr, 2004 at 08:00:28am
yeah that is another way to do it and just have one bleed valve! Good thinking! |
21st Apr, 2004 at 07:25:10pm
Shortening the actuator arm would increase the boost a bit???
21st Apr, 2004 at 08:22:02pm
with an in car boost adjuster its easy to adjust your boost when your driving i do it on the motorway. on where to fit ive put mine on the right hand side of the coloum just under the dash not to difficult to reach and out of the way of your mate or misses that might give it a twiddle when you nip in to pay for petrol or get a paper no longer a series, but still 1.3 turbo.
21st Apr, 2004 at 09:44:34pm
Might help mate, worth a try as it costs nothing! |
21st Apr, 2004 at 10:56:59pm
Been thinking about this (Uhoh!!!!!)
Edited by cordantium on 21st Apr, 2004. |
