| Home > Help Needed / General Tech Chat > bleed valves | |||||||
141 Posts Member #: 162 Advanced Member |
21st Apr, 2004 at 01:38:46am
hi there you said about fitting a twin bleed valve, i have got a bleed valve with 3 lines coming out of it. wat is the best way to conect it up. |
21st Apr, 2004 at 08:04:26am
Either will do the job. I fitted mine into the ecu pipe to make it easy. Works fine. |
