| Home > Help Needed / General Tech Chat > Stiff pistons! not sure what i've done wrong. | |||||||
12 Posts Member #: 1249 Member |
21st Sep, 2006 at 05:12:46pm
Hi guys, I'm very new to building engines and learning all of this as i go along. Still i'm determined to build my engine myself. I seem to have run into a problem in putting the pistons back in and not sure where i've gone wrong.
21st Sep, 2006 at 05:33:38pm
New rings on a fresh honed block do give a considerable resistance.
21st Sep, 2006 at 05:53:43pm
I'll admit i didn't gap them. Like i said complete beginner. Bit of a silly mistake i guess. So is there a method to measuring the gap? How do i adjust it if its wrong? File the rings? |
21st Sep, 2006 at 06:30:11pm
im sure there is a specicific torque you can set a torque wrench to, put it on the end of the crank if it turns before 'clicking' its a good indicaton thats nothings too tight. I couldn't quote the figure though, maye someone else knows?
21st Sep, 2006 at 06:51:29pm
On 21/09/2006 18:30:11 matty said:
im sure there is a specicific torque you can set a torque wrench to, put it on the end of the crank if it turns before 'clicking' its a good indicaton thats nothings too tight. I couldn't quote the figure though, maye someone else knows? Its definately worth gapping the rings first though! ![]() Cant see how that would work considering the variables involved such as the bore finish, oiled or not (I'd hope, not), type of rings and bore size. On 26th Oct, 2004 TurboDave16v said:
21st Sep, 2006 at 06:58:07pm
Well i've just gone out and removed all the pistons and placed the rings into the bores on there own and measured the gap. Is this the correct method? If it is then the gaps i had were within the tolarences in the manual. Yes the bores were all oiled before i put the pistons in. I did expect a bit of stiffness due to the honed bores but i can't even turn the crank by hand and thats with only one piston in the block! With all four in it would be impossible to turn judging by the first one. |
21st Sep, 2006 at 07:03:04pm
fit the piston and rings, see if you can move it up and down the bore by hand, if so is shouldn't stop the engine turning.
21st Sep, 2006 at 07:17:23pm
could be a main or big end beaing making it tight to turn if your sure the pistons are all ok. no longer a series, but still 1.3 turbo.
21st Sep, 2006 at 07:36:16pm
Yea i got the offsets the right way round on the pistons. I can't move the pistons up and down the bores by hand, even without them connected to the crank. I'm beggining to wonder if maybe i should have just payed someone to do this for me. I've clearly done something wrong somewhere. I really wish i was more of a patient person lol. |
21st Sep, 2006 at 07:45:47pm
i wouldnt stress too much, just pop the pistons out and gap them "Turbo's make torque, and torque makes fun"
21st Sep, 2006 at 07:55:23pm
Have you definately put the right rod caps on the corresponding rod?
21st Sep, 2006 at 08:10:18pm
All end caps were put back on the correct pistons and all pistons will be in the correct bores. They are stiff when they are not connected to the crank. I've checked the gaps in the rings with the rings placed into the bores on there own. Is there another clearance i should be checking other than the one at the gap in the ring. Could the finish of the bores be the problem? i used one of the hones you attach to a battery drill and ran that up and down the bore, but just enough to remove the glaze. |
21st Sep, 2006 at 08:37:03pm
When you ran the hone up and down the bores, did you make sure that you kept it moving so that the grinding marks were at a reasonable angle?
22nd Sep, 2006 at 07:21:46am
On 21/09/2006 18:51:29 Mini Sprocket said:
Cant see how that would work considering the variables involved such as the bore finish, oiled or not (I'd hope, not), type of rings and bore size. Are you hoping he's not oiled the rings when fitting them? On 13th Jul, 2012 Ben H said:
22nd Sep, 2006 at 10:11:19am
Where abouts are you?
AlexF |
22nd Sep, 2006 at 10:12:05am
Cant see how that would work considering the variables involved such as the bore finish, oiled or not (I'd hope, not), type of rings and bore size. Are you hoping he's not oiled the rings when fitting them? Yes On 26th Oct, 2004 TurboDave16v said:
22nd Sep, 2006 at 10:25:00am
Cant see how that would work considering the variables involved such as the bore finish, oiled or not (I'd hope, not), type of rings and bore size. Are you hoping he's not oiled the rings when fitting them? Yes WHY???? AlexF |
22nd Sep, 2006 at 11:11:43am
I oiled my rings and bores!
Edited by richminiturbo. on 22nd Sep, 2006. |
22nd Sep, 2006 at 12:34:35pm
Of coures you grease rings, skirts and bores. If not, the pistons and bores would be ruined before you even start the engine. On 13th Jul, 2012 Ben H said:
22nd Sep, 2006 at 12:52:23pm
Didn't "my fist turbo" have a similar problem the other week. He could not get his oil control rings in at all!
22nd Sep, 2006 at 01:26:00pm
Hi thanks for all the replies. I live in Essex so not sure just how local i am. Probably not. Yeah when i put the pistons and rings in everything was literally soaked in oil. The oil control ring sounds hopeful as it was different to the origonal metro ones. Instead of two rings and a spring it has the spring inside a larger ring kinda combines the other two that would be in the origonal, if that makes sense? I'll have to make another attempt later with just the oil control ring. Will report back later with my findings. |
22nd Sep, 2006 at 01:32:44pm
where in essex? PM me if you like. On 28th Aug, 2011 Kean said:
22nd Sep, 2006 at 01:37:51pm
On 22/09/2006 12:34:35 Vegard said:
Of coures you grease rings, skirts and bores. If not, the pistons and bores would be ruined before you even start the engine. Depends on the rings. Oiling rings is bad as it prevents them bedding in propperly in the first few minuits of running. After all, oil prevents metal to metal contact and that is what you want with rings and what they are designed for, its the seal, they need to bed in and wont if oil is pressent. Well ok thin oil such as wd40, but then that almost certainly evaporates off when the engine is started. Its the only reason oils with friction modifiers are not used on run in period. Ive never heard of grease being used?? This catalogue has some very usefull information within it. and its not just for their special gapless rings but for their conventional rings too. http://www.totalseal.com/pdf/TS_2005_Catalog.pdf Edited by Sprocket on 22nd Sep, 2006. On 26th Oct, 2004 TurboDave16v said:
22nd Sep, 2006 at 02:10:46pm
The oil on rings and piston skirts will be gone in a flash once the engine fires up. Then everything will be back to "normal". You don't think pistons run dry in an engine do you? Well, they don't! On 13th Jul, 2012 Ben H said:
22nd Sep, 2006 at 02:28:44pm
As much as it pains me to admit it, I am with Vegard on this subject.
