| Home > Technical Chat > rod/piston combos | |||||||
3596 Posts Member #: 655 Post Whore Northern Ireland |
21st Sep, 2006 at 06:50:21pm
I was having a nosey at one of the retailers.
21st Sep, 2006 at 07:04:09pm
Problem with long rods on long strokes with relatively small bore IE under square, is, the rods foul the bottom of the bore. Spose it depends on what you mean by longer. Pistons already available by JE with low compression hight, something like 6mm if i recall and also have a smaller diameter pin requiring the little end bushing.
