| Home > Help Needed / General Tech Chat > MPI tuning | |||||||
![]() 520 Posts Member #: 189 Post Whore Norway |
23rd Sep, 2006 at 05:52:20pm
I will soon get a VW Touran as company car, so the 156 have to go www.shag.no |
23rd Sep, 2006 at 06:28:30pm
First thing anyone should do on an MPi is swap out the lathargic 2.7:1 final drive.
23rd Sep, 2006 at 06:41:38pm
On 23/09/2006 18:28:30 Mini Sprocket said:
First thing anyone should do on an MPi is swap out the lathargic 2.7:1 final drive. Doesnt this meen it wil loose the comfort at highroads?? Usualy stage three tuning stuff, LCB, K&N, straight through, gas flowed head stage three ish and deffo not tunnel port. The Kent 274 cam is the only cam you should use as its speciffic to injection. Next to that is big bore. Oh and remove the peice of plastic that stops the throttle opening fully.
Once you add more to the list above, it starts to 'drive' pants Thanks thats about what I would like to do :) MPis and SPis will never be impressive and a good drive at the same time. Big bore gives easy torque and doesnt change the drivebility, but remember that the MPi blocks are seemingly getting rarer, so much so that i recon they will be as sought after as the Cooper S blocks. Overboring to 73.5 renders the block scrap when its worn, and ther are a LOT of people going this route on MPi's
Overboring is not an option as long as the engine dosent need it. I am a fan of trying to get the most use of the block, and not get it bored out more than it realy needs :) www.shag.no |
23rd Sep, 2006 at 06:50:16pm
yes, but a 3.1 would be more than adequate????
My plan is to get a MPI-mini for my wife and fun driving. But what can be done with the MPIs to get some more bananas?? I also want to get 10" as it looks so good, would fiesta calipers and 7.9" fit??
