| Home > Technical Chat > egt probe | |||||||
![]() 508 Posts Member #: 487 Post Whore westbury, wiltshire |
23rd Sep, 2006 at 07:35:03pm
where is the best place to put this, i would of thought as close to the turbo outlet as possible "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
3596 Posts Member #: 655 Post Whore Northern Ireland |
23rd Sep, 2006 at 08:07:29pm
Ideally as close to the exhaust valves, but thats rarely practical..
24th Feb, 2007 at 11:05:06am
sorry to dig up an old thread, but got a few questions
1425 Posts Member #: 690 Post Whore Norfolk |
24th Feb, 2007 at 11:40:59am
ideally you'd need one in each branch of the manifold. I did this with my engine when it was 5 port and we ran it on mapped ignition for the first time. I'll dig a piccie out soon. The probes only break if you abuse/bend them, they only need to poke down into the port a little way.
If Carling made Mini engines
24th Feb, 2007 at 11:53:32am
On 24th of Feb, 2007 at 11:40am johnK said:
ideally you'd need one in each branch of the manifold. I did this with my engine when it was 5 port and we ran it on mapped ignition for the first time. I'll dig a piccie out soon. The probes only break if you abuse/bend them, they only need to poke down into the port a little way. On my n/a engine we were getting un-even temps from the middle cylinders to the outers, a few degs extra advance on the niddle cylinders grought the temps into line and pulled 4/5 bhp extra from the engine. JK Interesting stuff! back when the MS code was being thought about, i posted about a test Dave Walker did on a CVH running different timing on the inner and out cylinders, I thought this might be a useful addition the MS code if it wasn't too much hassle to add (probably would be though). On 28th Aug, 2011 Kean said:
24th Feb, 2007 at 06:52:55pm
theres a pic of the egt probes in position on my n/a engine in one of my folders---can't figure out how to do the link - sorry!
24th Feb, 2007 at 08:09:24pm
On 24th of Feb, 2007 at 11:05am joeybaby83 said:
sorry to dig up an old thread, but got a few questions Do they tend to break off much Stevie? Still learning about egts atm but I wouldnt have thought it would be of any use after the turbo? as wont the turbo take different amounts of heat from the exhaust gas depending on its efficiency, boost etc? so comaring readings from other builds/setups would be futile? or would dangerous temps be so obvious that it doesnt make much difference? also, if you were to place it on the manifold, would it be better to place it on an outer branch? as not being siamesed the reading would be more like a conventional engine? And lastly, if anyone on here has done this, where did you place yours, and what sort of reading are you getting? Generally, no. But a few head gasket incidents took their tool.... And it only needs to break once. Although it depends how expensive your turbo is, whether it matters or not !!! Ideally you want the probe as close the the valve as possible, so you are getting a good indication of EGT's at the valve. After all, its burnt valves you want to prevent ! I think some can handle around 900degC, but anything over that can be pushing things a little. Depends on the valves too. Not sure what sort of temps a turbine wheel can handle, but Id think idealy you dont want that over 1000degC either. 9.85 @ 145mph
24th Feb, 2007 at 08:17:37pm
the newer probes handle 1000 deg c indefinately and short bursts of 1200deg c "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
26th Sep, 2007 at 12:34:35am
nogin, what do you mean by newer probes? presuming you dont me the k type?
26th Sep, 2007 at 07:04:18am
Any body ever tried something like a PT100? Much faster to react than a K type and more robust too. Every day is a school day ...........
26th Sep, 2007 at 06:45:52pm
Nope...I have recently aquired some larger diameter K type probes....
