| Home > Help Needed / General Tech Chat > Longer rear arms | |||||||
30 Posts Member #: 1213 Member Cyprus |
23rd Sep, 2006 at 08:02:25pm
Anybody knows how can i modify my rear suspension arms and make them longer like the australian moke? I think those are about 7cm longer than the normal arms. I know that there is an aluminium kit but thats too expensive...about 600GBP
23rd Sep, 2006 at 08:06:11pm
Unless someone could make custom tubular arms from chromoly steel ???? 9.85 @ 145mph
23rd Sep, 2006 at 08:09:55pm
is that the only way to use more than 13inch wheels? |
23rd Sep, 2006 at 09:44:08pm
On 23/09/2006 20:02:25 ClubmanTurbo said:
like the australian moke? are they?? i never realised that i shall get my tape measure out you will it hard to cut them cut and welded as they are cast, although it is possible however would you want to risk it, the arms get quite a hammering, probably best to get some custom tubular ones made up im sure ive seen some tubular arms that fast carl on here made up, might be worth asking him... |
23rd Sep, 2006 at 10:22:12pm
The arms are cast steel - not grey iron - so would be pretty easy to weld once you'd shot-blated them inside and out I'd have thought? On 17th Nov, 2014 Tom Fenton said:
23rd Sep, 2006 at 11:19:56pm
turbophil has 14" wheels on his mini, pretty sure he has standard back arms On 15th May, 2009 TurboDave said:
23rd Sep, 2006 at 11:48:35pm
i think you can get spacers from watson for the vaux/honda conversions that space the whole rear hub assemble outward which enables much larger wheels and madder offsets to be used. "Turbo's make torque, and torque makes fun"
24th Sep, 2006 at 06:54:12pm
If you extended the arms by 7cm on my car I wouldn't be able to fit 13", they'd just smack into the rear valance. I've 2cm maximim gap. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
24th Sep, 2006 at 07:44:21pm
I had 235/50/13's on my fortech kitted mini years ago,had to trim/smooth where the arms mounted to the subframe a bit
