| Home > Help Needed / General Tech Chat > To cool, or not to cool?? Help please!! | |||||||
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
26th Sep, 2006 at 07:29:54pm
Hi all, spent a few hours last nite reading old threads on oil coolers, a small amount of confusion from what I have read, people with varying opinions (which is fine) Am I right in thinking that it is ok not to run a cooler for fast road use as long as the oil temp stays around the 100dec (monitored by a temp gauge) and where does the 100dec temp come from, who says thats the temp it should be? just for my own curioity?? The other thing im curious of, is if you dont use a cooler, do you plumb in the what I asume to be heater (correct me if its not one??) that is part of the oil filter housing? Any help with this Im gratefull for, sorry to go over old topics.
26th Sep, 2006 at 07:57:47pm
i't personal preference really,
26th Sep, 2006 at 09:11:54pm
ive heard that the optimum oil temperature should be around 95 degrees, and that most a series applications dont warrant one.
Site Admin ![]() 1921 Posts Member #: 333 Post Whore Tadley, Hampshire |
26th Sep, 2006 at 09:14:21pm
I think optimum is about 95degC, you obvisouly don't want to let it get to 140degC as that's when it starts to degrade right?
26th Sep, 2006 at 09:18:44pm
http://no-rice.com/nicky/cooler2.jpg
![]() 695 Posts Member #: 984 Post Whore Westhoughton, Bolton |
26th Sep, 2006 at 10:07:13pm
Is recommended to have one if you have a sump guard as it restricts the flow of air to the cooling fins on the sump. |
27th Sep, 2006 at 06:46:57pm
Thanks peeps, thats most appreciated, only been a member a few weeks, and cant believe how helpfull everyone is its top banana! Another thing with regards to cooling, when using a t2 off a R5 GTT the water cooled core that is on the t2 fitted to the phase two GT's is it needed if the oil temp is never too exessive? The R5 turbo never had much of a cooler, all that it had was a few passes through the rad, For cooling or heating (like the metro oil filter housing) im not sure? I find it a little odd that some car manifacturers fit them when unnecessray? My old Bmw 325i SE had one but the oil never got hot enough to warrant one? Whats the reasoning behind it all?
164 Posts Member #: 1271 Advanced Member Berkshire |
27th Sep, 2006 at 07:01:26pm
oil coolers cant do any harm tho can they? surely the least they can do is able the engine to hold more oil than usual? |
27th Sep, 2006 at 07:03:32pm
On 27/09/2006 19:01:26 mic said:
oil coolers cant do any harm tho can they? Yes they can believe it or not, if the oil is constantly kept at too low a temperature, this can be just as bad as it getting too hot. Fitting a thermostat with an oil cooler is a MUST in my opinion, that way the cooler radiator is only bought into play when required.
