Home > Help Needed / General Tech Chat > MegaJolt Switched outputs
LukeAnsley
Member #: 193
I was just wondering what everyone uses the switched outputs of the megajolt system to switch.
i only ask as i am currently building up the megajolt in a ecu case and was going to fit some relays in there, just to try and tidy the wiring up.
Post anything that you switch if possible.
Thanks
colas
Member #: 102
Pennsylvania USA
I have 4 LED's. I use them as shift light. They light up at different RPM's.
cooling fan.
Kean
Member #: 341
aka T2clubby
South Staffs
2 Stage boost when I can be arsed to wire it in *tongue*
Once I get mine fitted im tempted to plum in a bit of water/methonal injection to see what difference it makes!
Or during the festive season christmas lights. Lol
LukeAnsley
Member #: 193
That was also what i was thinking of doing, water injection. What kind of set-ups have people used for water injection and with what advantages have they seen. I am not sure whether to go for internal water injection or just have spray jets spraying over the intercooler.
There has been many discussions on water injection, from what i gather the main problem is trying to meter the water at all rev ranges, thats the advantage mj you can switch it on and off as needed!
Not too sure on injections methods as ive only just started seriously looking into it.
I was going to use it to help with my pinking last year but since then realised it wasn't the answer to another problem but an oppertuninty to get a few more bananas and curley wurleys. :)
IMHO it would be more adantageous to use as injecton instead of spraying onto the intercooler, as it has more benefits than the cooling aspect e.g hydrogen and oxygen. *wink*
LukeAnsley
Member #: 193
Thanks for the reply's i was thinking that i could use the megajolt to turn on some water injection at a preset boost pressure, might be worth giving it a go.... just need to get the rest of the front end back together first, but i think that i may try and get a water injection spray nozzle into the inlet manifold and see what it does.
Thanks
