| Home > General Chat > Getting more speed out of my mini cornering. | |||||||
138 Posts Member #: 138 Advanced Member |
30th Sep, 2006 at 01:32:33am
I run a mini cooper with sound deading mat removed, standard glass. standard seat. almost everything are standard.
30th Sep, 2006 at 06:43:20am
Fit negative camber front arms, then have it set up. Tyre pressures sound on the high side to me.
30th Sep, 2006 at 06:06:18pm
I thought you needed a couple of degrees toe out on the front of a fwd car.
30th Sep, 2006 at 07:01:27pm
1/16 of an inch of toe out on the front is good. for a roadgoing car I would suggest 1.5 degree negative camber on the front, zero or 0.5 degrees camber at the back. noe toe at the back and 3 degrees castor at the front.
Edited by miniminor63 on 30th Sep, 2006. |
30th Sep, 2006 at 07:29:47pm
iv been told this is good for 10" wheels and what i might try but ill prop leave it up to the bloke that sets it up...
My build thread..
30th Sep, 2006 at 08:43:58pm
-1.5 camber thing is useless. It changes depending on ride height. -1.5 camber on what height ? |
969 Posts Member #: 47 Post Whore Not very sunny swanage |
30th Sep, 2006 at 08:50:05pm
surely you set the camber on whatever height you normally run the car at???? And on the 7th day........... God created turbochargers! |
30th Sep, 2006 at 09:04:28pm
at rideheight yes! |
1st Oct, 2006 at 10:14:38am
On 30/09/2006 19:29:47 josh_tacon said:
iv been told this is good for 10" wheels and what i might try but ill prop leave it up to the bloke that sets it up... FRONT -1.5 camber 1/16th toe out 4degs caster REAR -0.5camber 1/16th toe in what do you think? perfect for a road car On 5th Sep, 2011 Vegard said:
1st Oct, 2006 at 12:46:01pm
i have fitted solid subfame mounts, adjustable tie rods (not set up propoly!) hilos, gaz adjustable dampers all round and its all slightly lowerd.
My build thread..
