Home > Help Needed / General Tech Chat > sandwich plates???????
cheekym0nkey
Member #: 180
Northants
Was having a talk with a man from "turbo technics" About lowering the compretion on an mini engine! He advised a "Sandwich plate" Which as he decribed is a thin plate that goes inbtween the head and block. Has any one done this as it sound like a pile of bull to me? It would also mean using two head gaskets! More to go wrong if You ask me! When i asked where to get one he said that any good machine shop would be able to make one using a head gasket as a template???????? *oh well*
You'd be best getting one laser cut from Steel. If anyone is interested, i already have the 'Head Gasket' shape geometry ready for such a task...
As regards their use... You don't need it on an A-Series. You only need them on engines where there is no scope to open the chambers out, or the piston design allows little or no machining...
dan
Member #: 93
Could it be an efficient way of dropping the compression dave, or is there more benefit to re-shaping/opening out the chambers in the head for best performance?
