Home > Help Needed / General Tech Chat > Overboosting - causes and cures???
cordantium
Member #: 31
62horses at the wheels and counting
As per title really.
Engine - standard. running bleed valve not fully closed but set at 4/5psi. Dump valve and intercooler fitted.
Problem is she keeps overboosting on occasions in 4th. Boosting upto about 12psi. Can't seem to find a common link and it doesn't happen all the time.
Do I really need to worry about it??
I'm looking to up the boost and do a few more tweaks but I don't want to raise the boost, the engine overboost and it all to go bang!!!!!!
Thoughts and advice please.
TA Muchly
Keith
dan
Member #: 93
Hello Keith, you best bet might be to replace any actuator type hosing, a small leak might open and close irractically. Its fairly cheap aswell, and would put you mind at rest.
Yep, good point, might have a source for this tomorrow *smiley*
If anyone knows the ID though it would be appreciated!
Iain
