Home > Help Needed / General Tech Chat > smokey breather
Nick
Member #: 154
Midlands
managed to get me engine running properly for the first time tonight just to get up to temp so i can re-torque the head down.
only problem is that i put a K&N filter on the clutch cover breather and its kicking out a fair bit of smoke, any idea's what could be causing this? do i just need to give it a run to clear it out or could it be something worse? also gettin a fair bit out of the exhaust too, but that seems whiteish so i dont think its oil burning.
cheers, Nick *happy*
P.S fook it sounds nice, been a while since i had me car running let alone with a turbo engine!
evolotion
Member #: 83
Glasgow, Scotland
Only experience i had of a smokey breather was cracked compression rings.. almost white smoke could be eather this time of year or burning LOTS of oil, i know coz iv had that too *tongue*
check the colour of your plugs, and if you can do a compression and/or leakdown test.
Denis O'Brien.
mr t bo
Member #: 78
milton keynes
I had the same problem turned out to be cracked piston rings. I did a compression test found the bore that was slightly down on power and put some oil down the bore to seal the ring then tryed a compression test again.... This showed the same compression as the other three bores. i wouldnt take it for a run to try and clear it i did as a result i cracked the piston and scored the bore. cost me a lot of dosh :(
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
That smoke is from blow by... exh gasses are getting down past the rings...
It means only one thing I am afriad... worn engine!
Alex
AlexF
