Home > Help Needed / General Tech Chat > Soild Tower Front Subframe mounts
Graeme
Member #: 264
Southampton
I was going have a go at making some of the above myself. Does anyone have some not currently attached to their car and a vernier/micrometer and be able tell me the dimensions please, a sketch would be very helpful?
Yes, Im getting there.....
www.itsmuckingfagic.com
Dangerous
Member #: 417
Quick sketch NOT autocad
You need to cut a slice of the top ones to clear the angled bracket they fit behind
Graeme
Member #: 264
Southampton
Wicked, thank you very much, exactly what I needed. I assume its 2 of these per side/mount, 1 above - 1 below.
I'll make up a CAD drawing and see if I can slip it into the 'work to do' pile down in the machine shop at work!
Thanks again
Dangerous
Member #: 417
Heres the top one with the slice missing,Best idea is make a few sets and sell some on ebay
Graeme
Member #: 264
Southampton
I've just noticed that from the dimensions the max radius can only be 4mm, I'm sure it wont make much difference either way.
Also, out of interest what material are they made from. I'm assuming aluminium will suffice.
(Right click and "save picture as.." if image is unclear
Edited by Graeme on 9th Oct, 2006.
Supereds
Member #: 1244
Bagshot, Surrey
Sorry couldn't find my drawing of the mounts. I made my own front tower, teardrop & solid front sub rear floor mounts out of Titanium.:)
