| Home > Technical Chat > suck thorugh turbo system!!!!! | |||||||
117 Posts Member #: 144 Advanced Member |
27th Apr, 2004 at 09:47:29am
i am looking into building a turbo mini, i am going to use a suck through turbo system, i would like to know some moire details about this method of turboing a mini, could i use a 40mm weber carb or summat similar? or would i have to stick with the su? |
27th Apr, 2004 at 11:11:45am
If you are building a suck-through system you'll be starting from scratch so you could use any carb you wanted.
28th Apr, 2004 at 12:16:31pm
i have got evrything to do the std system, but i want my turbo up near the wiper motor, dont have to cut the bulkhead and its in direct cool air flow.
![]() 164 Posts Member #: 206 Advanced Member Milton Keynes |
28th Apr, 2004 at 12:22:35pm
Will a blow through turbo be OK with going suck through. wont the seals need replacing ? 9 valves, 4 wheel drive, 3 cylinders, 1 turbo, which got nicked |
28th Apr, 2004 at 01:27:35pm
yeah i remember something about that, fuel is going through the turbo, something i wouldnt fancy if your seals started leaking!
28th Apr, 2004 at 02:19:14pm
ah, i dunno bout the seals, possibly a problem.
28th Apr, 2004 at 04:26:30pm
Steven,
Edited by PaulM on 28th Apr, 2004. 9 valves, 4 wheel drive, 3 cylinders, 1 turbo, which got nicked |
28th Apr, 2004 at 04:58:40pm
Giallofly's carb is 20 years old without a rebuild and running lots more boost than it was designed to take!
4th May, 2004 at 05:52:45pm
i have decided to stick with the normal turbo setup, i am still having to use the turbo off a nova 1.5 td. it will spin up very quickly and still bost enough, i will contact the turbo manufacturers about the temp issues. i need to make a new exhaust manifold, does anyone have any pictures of tubular turbo exhaust manifolds they could send me???
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
15th Sep, 2004 at 05:50:23pm
I am looking at doing my own Bini supercharger conversion. In fact I am almost ready to rock. I look as if I have no choice apart from to do it suck through. Lets say that the blower sucks through the carb like a normally aspirated 2L engine. Would you put a 1/3/4" SU on a 2L engine? Sure a Weber is better but you are going to be needing some serious airflow. I have only just thought about this and so I haven't worked out the answers myself but.....It looks to me like a carb for suck through is going to require some serious mods. The books I have read say little about suck through. With a blow through, you just need a needle change (I think). The noise from a Weber is due to one port going "sucksuckgapgap". It makes a kind of odd note. If you put a turbine between it and the intakes, it will shut this right up.
Bugger off, I'm getting there. |
![]() 2641 Posts Member #: 19 Post Whore newcastle |
15th Sep, 2004 at 06:17:13pm
sorry stu , don`t have time to read all the books , i actually own/drive/use a turbo mini!! Everyone knows that instructions only have to be read if the thing doesn't work....
15th Sep, 2004 at 06:41:06pm
Steven, a stock turbo on a stock engine is sized for that engine. Running even 50% more boost, menas the turbocharger is no longer sized right... Sure it may still make boost, but will be way off the compressor map... Off map = no point...
