| Home > Help Needed / General Tech Chat > su needle | |||||||
119 Posts Member #: 772 Advanced Member new york |
5th Oct, 2006 at 09:55:17pm
what needle to run 10 psi?
5th Oct, 2006 at 10:05:19pm
its difficult to say depends on your engine, there all different and one will probably need profiling to suit your engine by the rolling road guy.
5th Oct, 2006 at 10:06:39pm
NO you need to order one from Avonbar
5th Oct, 2006 at 10:31:09pm
received two needles from avonbar one was 10 psi the other
5th Oct, 2006 at 10:36:06pm
at a guess id say they started life as the bdd and bca needles but have probably now been modified by avonbar. ring them just to confirm. no longer a series, but still 1.3 turbo.
5th Oct, 2006 at 10:36:57pm
No avonbar havent
5th Oct, 2006 at 10:41:43pm
thought of that after my post did email them
5th Oct, 2006 at 10:49:22pm
the same
6th Oct, 2006 at 06:47:37pm
The one that is thinnest at the pointy end will be the higher boost level one
6th Oct, 2006 at 09:03:39pm
ok they start out as standard needles then they are reprofiled |
6th Oct, 2006 at 10:20:08pm
correct!
