| Home > Show Us Yours! > Rear Turbo Dyno Results - At Last | |||||||
141 Posts Member #: 954 Advanced Member Fort Collins Colorado USA |
6th Oct, 2006 at 04:03:04am
http://img.photobucket.com/albums/v233/wke...l/turbovsna.jpg
1275 with Back Door Turbo |
6th Oct, 2006 at 04:08:40am
Let's try to get the images to show up directly.
6th Oct, 2006 at 04:14:21am
By the way, it does have a muffler now. My neighbors were very tolerant, but my wife found the car very embarassing without a muffler and I was always driving very gingerly past police cars. A glasspack after the turbo makes it much nicer. 1275 with Back Door Turbo |
6th Oct, 2006 at 05:35:23am
Think I mis-calcuated the mythical flywheel HP actually. 95HP at the flywheel only allows 18% for losses. Seems many are seeing 22-25% loss. Hallelujah, Easter Bunny brings 100+HP at the flywheel.
703 Posts Member #: 105 1st to provide proof of a running Bimmy Conversion! Brisbane ,Australia |
6th Oct, 2006 at 07:29:47am
How does the oil feed/return system work having to get it back to the engine??? where have you put it back too?
www.miniman.com.au
6th Oct, 2006 at 07:34:11am
well done ff pioneering in fort collins ! Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
6th Oct, 2006 at 11:12:24am
whats the lag like?
AlexF |
6th Oct, 2006 at 01:02:11pm
There is a scavenging pump near the turbo which sends the oil back through a plate over the mechanical fuel pump mount.
6th Oct, 2006 at 07:04:26pm
How does the boost curve compare on the road, vs the Dynojet ???
6th Oct, 2006 at 08:06:34pm
Boost curve was pretty much identical. This is a Dynojet, which uses the weight of the rollers as the load. In fact I did the pulls in 3rd gear because it accelerated so slowly in 4th. The rollers model a 3000lb. chassis, a bit much for the torque of 1275cc even huffed.
![]() 88 Posts Member #: 720 Advanced Member Gloucestershire |
7th Oct, 2006 at 08:17:41am
Well done - I love this install especially the fact it's on a stock motor. I think it's brilliant. What CR is this engine (assuming totally stock), anyone know?
Edited by Daniel on 7th Oct, 2006. |
7th Oct, 2006 at 01:02:12pm
I'd be interested to know the turbine spec myself - just to see how what you say about the boost / rpm compares. :) On 17th Nov, 2014 Tom Fenton said:
7th Oct, 2006 at 02:09:16pm
Timing is either 28 or 30 degrees @ 4500RPM, can't remember which.
8th Oct, 2006 at 04:29:02am
oh - That was you! LOL!
12th Oct, 2006 at 05:35:34am
Lagged pipe improved low RPM boost a bit. Now seeing ~4psi @ 3000RPM, ~2psi @ 2500RPM.
