Home > Help Needed / General Tech Chat > late front subframes into early cars.
ive never tried this, but will a late single bolt frame fit a MK1 shell.
i'm guessing it will as the big hole is there to bolt through.
are there any differences in the buulkhead detail brelow the baulkhead crossmember.
cheers carl
It will only fit a hydrolastic Mk1 as dry cars dont have the big hole. Obviously you would need mounts from subframe to floor and teardrops from subframe to front panel which MK1s dont have.
What are you doing?
Paul
I knew you'd know,lol.
someones asked if my frames fit mk 1 shells,
so basically it will fit dimensionally , i just need to pickup the twin bolt fixings,
is this correct Paul,
carl
i thought all the mk1's had the hole there, I guess my mk1 was a hydro one then...
i've wondered if an early subby would go in a later body as i prefer the early rear mount's.
Why? Just fit some solid mountings and you've achieved the same thing.
i just like the fact that the rear mount is actually on the fold with mk1's whre its strongest.
i know it makes sod all difference, but i justr prefer it.
Carl
Member #: 95
liverpool-on-sea
isnt the mk1 bulkhead hollow where the big hole is so itd have to be strengthened with a tube or something to stop it squashing.
Nick
Member #: 154
Midlands
yeah, i was looking at it on my twin bolt shell and it'd need sleeving to stop it squashing.
Youre quite right, I forgot about that. And yes to Fastcarl.
Paul
Edited by paul wiginton on 10th Oct, 2006.
I was thinking the same. Isn't there a plastic sleeve in the twin bolt cars?
