Home > Introduce Yourself > New and Irish
Frisco
Member #: 1304
Ireland
Hi folks.
I have just come across this site after buying a turbo.
Im from Meath Ireland and have a 1981 city which is now finally being rebuild
(ive had it 6 years in dry storage)
So after being distracted by 2.0 opels i thought the mini needed a little more punch
Hence the turbo!
Im going to be using a late n/a 1275 a+ for the conversion and from what ive been reading here this isnt a big problem.
Ill change the pistons for the cheap ones on MiniSpeed, or does anyone have anybetter advice than that?
Im curious about lowering the compression ratio, is getting the head machined the only way?
Budget is tight (when is it not) but ill spend money where its needed.
Anyway hi
Quiet, can you hear it rusting?
t3gav
Member #: 229
Gavin@minispares.com
kent
Welcome, with regards to pistons the minispares mega pistons are very good and have plenty of meat to be machined for whatever size you like (up to i think 15cc), this will help in lowering the CR a fair bit.
hi there and welcome
please use the search facility on this forum
Most of the info you require has been posted before .....if not just ask
so....... get posting my friend we are all here to help!
T3Tone
Member #: 252
Sunny suffolk
hello and welcome
-MINI CLUBMAN 1380 TURBO-
jimmy
Member #: 829
essex
hello welcome
1293 Turbo mini
