| Home > General Chat > Another "what thread size is this?" post | |||||||
11th Oct, 2006 at 02:27:59pm
Hello again folks, just wondering...what thread size is the banjo bolt that goes into the block (securing the std oil pipe)?
11th Oct, 2006 at 02:46:30pm
11th Oct, 2006 at 04:07:35pm
cheers, needed some adaptors
11th Oct, 2006 at 04:23:08pm
UNF into steel/ cast iron UNC into ally, On 28th Aug, 2011 Kean said:
11th Oct, 2006 at 04:23:50pm
Definately looks UNF, looks to fine for UNC! https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
11th Oct, 2006 at 04:56:17pm
On 11th of Oct at 04:23pm mini13 said:
UNF into steel/ cast iron UNC into ally, Reasonably good rule - Apart from the head studs and thermostat studs? I think they're the only exceptions however? Actually - Isn't the speedo-drive retaining bolt some wierd thread aswell? On 17th Nov, 2014 Tom Fenton said:
11th Oct, 2006 at 05:27:25pm
oh yeah, forgot about the head studs and thermostat studs, arn't the rocker studs holes UNC too?
11th Oct, 2006 at 05:27:38pm
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
11th Oct, 2006 at 05:33:33pm
On 11th of Oct at 04:56pm TurboDave said:
Actually - Isn't the speedo-drive retaining bolt some wierd thread aswell? I think its 1/4 UNF?? we talking the one u shapped clip? I've seen the future and tbh its Pie
11th Oct, 2006 at 05:35:11pm
Oh btw i've got a 5/8 UNF tap which wont go into that banjo hole, however when i measured the bolt it indicated it was a 5/8 unf. Ive not had time to check it again since. I've seen the future and tbh its Pie
11th Oct, 2006 at 05:58:28pm
The SPi blocks were a metric size weren't they - worth checking? On 17th Nov, 2014 Tom Fenton said:
11th Oct, 2006 at 06:57:39pm
arent the oil filter housing to block bolts 3/8 UNC too?
11th Oct, 2006 at 08:29:20pm
11th Oct, 2006 at 08:35:19pm
Actually - Isn't the speedo-drive retaining bolt some wierd thread aswell? I think its 1/4 UNF?? we talking the one u shapped clip? It's 1/4 UNC infact. The only one on the entire engine. Both the rocker post studs and the ol filter holder are UNC, and I do think that the fuel pump is as well? However, a good rule is UNF in iron/steel and UNC in aluminium. BIR1 was full of 8mm though. Shame on you Mark!!
11th Oct, 2006 at 08:40:03pm
11th Oct, 2006 at 08:42:17pm
erm whats going on here? I havent posted the comments since the first time??? Alex - help!
11th Oct, 2006 at 08:49:11pm
ok so,
11th Oct, 2006 at 11:06:25pm
On 11th of Oct at 05:58pm TurboDave said:
The SPi blocks were a metric size weren't they - worth checking? I'm pretty sure that they are still imperial, but a different size / thread to the older blocks. I had fun trying to find an adaptor to put an oil cooler on my original engine, in the end good old Think Autos helped me out. Joey, What could you possibly want to know all these thread sizes for? If I wasn't a noisy busybody I'd say you were making some custom adaptors. Isambard Kingdom Brunel said:
11th Oct, 2006 at 11:52:56pm
On 11th of Oct at 08:49pm mini13 said:
ok so, UNC into aluminium, and unf into steel/ iron except for studs which are unc in boyh ally and steel. i just remembered the manifold studs too.... Haha, you're right :) Manifold studs are UNF. On 13th Jul, 2012 Ben H said:
12th Oct, 2006 at 07:48:57pm
On 11th of Oct, 2006 at 11:52pm Vegard said:
Manifold studs are UNF. oh yeah.... why does there always have to be an exception to the rule
13th Oct, 2006 at 04:13:02pm
unfortunatly for the life of me i cant find that tap, its somewhere in the garage, but with my mini stripped bear it must be burried under some shite off that Edited by andeh on 13th Oct, 2006. I've seen the future and tbh its Pie
18th Oct, 2006 at 06:37:55pm
Slightly side tracking but does anyone know how long the gearbox to engine bolts are?
18th Oct, 2006 at 06:41:57pm
1 1/4" seems to ring a bell but don't take that as correct without checking.
