Home > General Chat > Alex F - need some BMW info... (updated)
I could do with the wiring diagram for one of the BMW models that use the electric master water pump. all i need is (i assume) the engine diagram - basically the one that the electric pump is included on.
Good news is the pump is a brushless, but the controller is built into the back-end of the pump body. I'm damn sure pins 1&4 are ign live and earth, and have a suspicion I know what the other two are - but the diagram would help...
These could well work out to be a cost effective, HIGHLY reliable pump with massive flow potential.
It'd be helpful if you could assist... :)
Edited by turbodave16v on 24th Sep, 2007.
Coolio
Whilest on the subject of electric pumps, i'm waiting on this turning up to see if its any use. Thing is, it sucks rather than blows if you get my drift *wink*
Edited by Sprocket on 11th Oct, 2006.
looks interesting, how much did that set you back?
johnK
Member #: 690
Norfolk
BMW part number is 11517546994 - fits the 3.0l straight six as a start point - can get hold of wiring loom picture but not diagram - doh!
If Carling made Mini engines
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Looking into it...
There is a chance is uses a bus network.....
Alex
AlexF
On 11th of Oct, 2006 at 10:04pm Mini Sprocket said:
Coolio
Ah Bollox. After all that, and i even asked the guy, AND looked on my Laguna, its a fricken thermostat. Ah whell, cost less than a tenner including postage. I'll stick it back on ebay.
Had a feeling in the back of my mind. Knew it was too good to be true, Doh!!!
shane
Member #: 1246
Lowestoft, Suffolk.
If your looking for an electric water pump, the renault 21 turbo unit may be of use, it has a good flow rate, my apprentice had a 21 turbo for a while, he had it on the rollers and it was pulling 210 hp befrore they had to abandon the run (suspension fault, they couldnt keep the thing on the rollers), it seemed to be more than adequte for the job?
Thought that was just for the heater and heat soak cool down? Theres one on the Renault 19 also, as on many a Jag, Though, flow rates are small, some have used them to good effect with no issues.
AF,
Are you still at BMW?
Can you get me anything that resembles 'pin outs' or 'testing/troubleshooting' the pump or the pump circuit?
I'm tempted to spend the coin and purchase a WDS / manual, but if you can get me the info i'd sooner buy you a beer LOL
miniminor63
Member #: 672
The oversills police
Oslo, Norway
why not just buy a meziere pump from summit? it isnt that expensive from them (still cost a bit tho), and pump MORE than enough for our purpose. It also handles nicely to pump against a thermostat. the only problem with it the way I see it is that it is a bit big and heavy. I cant imagine the BMW item beeing any smaller though...
Simple answer:
I can fully control the BMW unit if i can get a little more info, and i trust it way more than a mezierre to be reliable long-term as it's a brushless motor, which also lends itself to a proportional control better than a brushed unit. Oh, did i also mention I can get new 'take off's for a lot less than the meziere? *wink*
miniminor63
Member #: 672
Oslo, Norway
ahh, all good points:) I think the meziere pump is supposed to be pretty reliable though.
Tazzy
Member #: 1677
Netherlands, The Hague
what models have the electric pump?
Basically the 2005> models with the six-pot motor (E90?). Don't have specifics as I'm not a BMW man at all...
I do recognise quality however, and these pumps are superbly engineered pieces of kit.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
I forgot all about this - sorry guys!
I'll look tomoroow!
AlexF
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Right - unless you want to get into the wonderful world of Bus Networks your out of luck.
The Pump has an ECU built in which comunicated to the Engine Management via a Bit Serial Interface.
Its not a simple PMW signal controling the pump speed, its actual network messages.
Alex
AlexF
Oh well - cheers anyway.
bloody germans making things difficult.....next they will design an automatic machine to place beach towels on sun loungers at 6am........
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
LOL @ tom
AlexF
Well, I'm not giving up on this. Reason is becuse i am looking at something that appears to look exactly like a brushless speed control. Time to un-solder some contacts and take the board out methinks.
evolotion
Member #: 83
Glasgow, Scotland
was about to say why not jstu get one and smash the case open and get dirty with the motor tht drives the pump itself :)
Denis O'Brien.
Becuase brushless motors are nothing whatsoever like a brushed unit... The controller is the heart of the unit.
Descision made - I'm going to smoke it or spin it this weekend. :)
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
I'll get you the pin outs tomorrow.
AlexF
