| Home > Help Needed / General Tech Chat > Help my turbo kills ignition coils! | |||||||
51 Posts Member #: 979 Advanced Member Auckland, New Zealand |
12th Oct, 2006 at 10:03:11am
Hi All,
1975 MkIII Morris Mini 1300 Turbo, 100bhp...if only it could run long enough to drive it legally! |
12th Oct, 2006 at 10:18:37am
What voltage is your alternator putting out?
AlexF |
450 Posts Member #: 449 Senior Member Oxford |
12th Oct, 2006 at 10:27:02am
2645 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
12th Oct, 2006 at 11:54:28am
Are you using the correct coil for the wiring loom? using a ballested ignition coil (requires 9v, used to ease starting on low battery charge) on a loom with out the resisted wire to the + terminal (pink and white) allowing 12v to the coil? this may be what is killing them? |
12th Oct, 2006 at 12:14:04pm
where is the coil placed? on the engine? this may vibrate and make the oil in the coil cool less efficiently. Then they boil and stop working very quickly. I ruined 3 coils in a month on my 9000 rpm redline 1071. After I moved the coil to the inner wing, all has been fine Edited by miniminor63 on 12th Oct, 2006. |
12th Oct, 2006 at 08:18:46pm
Hey i have no idea on the voltage that my altenator is putting out, i guess i should test that.
12th Oct, 2006 at 08:24:32pm
pretty sure all metros were balasted, specially the lecy ignition ones, I'd say 90% chance thats the problem. On 28th Aug, 2011 Kean said:
12th Oct, 2006 at 09:10:55pm
as stated above, the gold coil shouldnt be used with leccy ign... "Turbo's make torque, and torque makes fun"
12th Oct, 2006 at 10:34:08pm
You havn't got it wired backwards.or a radio suppressor on the wrong side
21st Oct, 2006 at 12:20:01pm
Hey all,
21st Oct, 2006 at 03:56:33pm
mine runs on 12v not baalsted 9v, so try running cable from fuse box ( unfused side) i recon yours is ballasted and the electy coils dont like that. always looking for them bigger bunches of bannanas |
22nd Oct, 2006 at 04:08:22am
Hey again,
22nd Oct, 2006 at 08:57:47am
you need to measure the voltage to the coil if its more than 14.7v then that will blow it to.
22nd Oct, 2006 at 10:36:55am
All MK2 1275 Metros had electronic ignition, not just the MG and turbo. |
23rd Oct, 2006 at 08:52:46am
i know mate but a lot of motor factors seam to give you a standard coil unless you as for a mg one thats why i stated it.
24th Oct, 2006 at 08:33:52am
Hey,
24th Oct, 2006 at 06:15:56pm
also check your float valve as well as this could be leaking past on high boost which will also give you a misfire as well. always looking for them bigger bunches of bannanas |
24th Oct, 2006 at 06:24:50pm
I'm using these coils with the standard electronic distributor.
25th Oct, 2006 at 08:17:47am
28th Oct, 2006 at 03:08:49am
Hey,
28th Oct, 2006 at 07:41:12am
ngk can sometimes collapse under boost , depend on the set, but they don't like charge pressure, I would try another set or better an other make, I personaly like volvo 480 turbo plugs, champion and bosch super 4 |
28th Oct, 2006 at 09:30:59am
Could it be your HT leads?
28th Oct, 2006 at 10:40:14pm
No i dont think it would be my leads aye they are good near new and of the 8mm High Temp Silicone type.
30th Oct, 2006 at 04:13:35pm
the volvo plugs are certainly not made by volvo , part n°3344899-4 engine : b18ft/b18ftm
31st Oct, 2006 at 02:07:19pm
a pic to show that this is not black magic, the plug nose go down in the chamber , it is also strong and with double copper core increase heat dissipation therefore decrease temp of the electrodes. |
