Home > Help Needed / General Tech Chat > oil from turbo to block. (t piece) Pic Please
MarkGTT
Member #: 1194
Shropshire.
Hi guys, I know that I need to use a t piece to attach the oil pipe from the turbo to the block in order to have the oil pressure sensor still attached,
however could someone please post a picture of theirs?
As mine looks like a bit of a bodge job, and is now leaking oil.. Not good. *frown*
Cheers.
Edited by MarkGTT on 16th Oct, 2006.
MarkGTT
Member #: 1194
Shropshire.
Hi, did anyone get a chance to do this for me? would be a big help.
cheers again.
Mark.
Nick
Member #: 154
Midlands
i'll grab a pic later dude, i'm using the one supplied in the avonbar kit. although i've got an elctronic sender rather than a switch.
MarkGTT
Member #: 1194
Shropshire.
cheers, i made my own up.. think that was my first mistake :)
will look out for the pic.
thanks again.
Nick
Member #: 154
Midlands
Is this any good for you?
......and fitted like this..
Did you use PTFE Tape on the threads? It makes a big difference.
An 1/8NPT thread will fit, but it should be an 1/8BSP, there only only pitch difference per inch but the BSP is a tapered thread!
Edited by matty on 17th Oct, 2006.
MarkGTT
Member #: 1194
Shropshire.
top blokes, cheers. mine is very similar, will try the PTF tape too, I have used a brake pipe union and pipe to move it from the front of the block to the near side, but the set up is the same. Can anyone see any problems with me doing this? length (about 20 cm) of pipe and diameter of standard brake pipe..
any thoughts?
cheers again chaps.
Dangerous
Member #: 417
I got 2 brass fittings on mine so I have oil presure gauge,oil pressure sensor and turbo supply.
Bud will remember he was bidding on them too *laughing*
Frisco
Member #: 1304
Ireland
All that stuff would be readily available and really cheap from a plumbers suppliers,
its the same as diesel lines to boilers*wink*
Quiet, can you hear it rusting?
Nick
Member #: 154
Midlands
that sounds about right, lol.
its either you or tom that starts bidding on the same things i'm watching.
shane
Member #: 1246
Lowestoft, Suffolk.
By the looks of those fittings they are they same as what I keep a stock of on my van, Im a refrigeration engineer, we use a fair few of those fittings, they are available from wholesalers like, Dean and Wood, and HRP, most cities have one? (dont know if this is any help?)
