Home > Wanted > speedo cable
Arun
Member #: 1294
i need a speedo cable to fit my metro turbo engine/box and match up with the '88 3 clock mini dash
if you have one or know what one i need help would be much appreciated
cheers
Arun
Dangerous
Member #: 417
You just need a mini speedo cable then,But you may have to change the output on the gearbox for a mini one.
Just undo the 3/8" nut (?) nut next to where the speedo cable goes and check the square hole the cable goes in is the right size.
Some metros had a smaller square in the cable
