Home > Help Needed / General Tech Chat > Filter King filter for turbo conversion
Minimad69
Member #: 1311
Yeovil, Somerset
I rescently purchased a Filter King fuel filter with pressure regulator to go on my mini but have now changed my plans and decided to go down the Forced Induction route *happy*
My question is will the Filter king and pressure regulator still be suitable for the turbo if the regulator is wound right open and fitted before the fuel pump? The filter has 8mm inlet and outlet unions.
I also purchased a New Fascet Fuel pump which is now useless as it only supplys a max of 5.5psi fuel pressure *frown* (new and boxed if anyone is interested and after one *tongue* )
And finally my last question, well for now anyway.
Im looking for a fuel pressure regulator with the return for turbos and came across this on ebay, the drawing looks like the Metro Turbo one but wanted some opinions before purchaseing :$
http://cgi.ebay.co.uk/FUEL-PRESSURE-REGULA...oQQcmdZViewItem
vegar
Member #: 189
If I dont get that "add" wrong it is for reducing the high pressure in a injected car/engine for setting up a carb wich dont need that much pressure. I cant understand how that will work in your aplication??
www.shag.no
Minimad69
Member #: 1311
Yeovil, Somerset
Thats what i am trying to find out. I bought the Filter King for my NA 1330cc but am now going for forced induction, just trying to find out if i can still use the filter side of it for a Turbo conversion.
that regulator in the ebay ad seems fine. i'd say your better off selling the filter and regulator then getting a cheaper filter off a modern injection car. think the focus one is good for a mini.
Minimad69
Member #: 1311
Yeovil, Somerset
the only thing that concerned me with the regulator on ebay is where it says 60psi down to 5pi
Ethel
Member #: 1293
Yorks
Certainly looks the very thing!
Fuel reg on a turbo needs to increase the fuel pressure as the boost rises so the petrol stays in the carb float chamber at the right level 'n isn't forced back down the fuel pipe. I suppose it's because BL used a pressure regulator intended for injection that you need an OTT fuel pump in the first place! Better option than the filter king would be a fuel filter (like the Focus one suggested) between the tank and the expensive roller vane pump you'll need to buy and fit near the tank. (Next problem waiting for your attention will be the fuel return)
Minimad69
Member #: 1311
Yeovil, Somerset
I have asked the seller the question so hopefully it will be what im after and vary the fuel pressure according to the boost pressure and not be fixed at the 5psi.
As for fuel pump, hopefully one of these will do the job nicely :)
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...AMEWN%3AIT&rd=1
Nick
Member #: 154
Midlands
or you could just buy one from minispares for alot less money???
http://www.minispares.com/Product.aspx?pid=37056
Minimad69
Member #: 1311
Yeovil, Somerset
nice one cheers bud666, think i will just buy one from mini spares for a lot less money
just tried ordering one, still out of stock, and theyve been out of stock of these for over a year afaik...
minimad69, which facet pump did you buy? was it the redtop??? If so I may be interested in buying it from you, or maybe part exchange as I may have some bits you need.
Minimad69
Member #: 1311
Yeovil, Somerset
Jimster, this is the exact i bought.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...em=130018310103
thanks anyway, but that will not do for me,
Minimad69
Member #: 1311
Yeovil, Somerset
no worries
Minimad69
Member #: 1311
Yeovil, Somerset
Tried to order one from mini spares but out of stock. spoke to them and they say their is no estimated delivery time from there suppliers so i went for the one off of ebay, tad more expensive but turned up the next day.
martpaul
Member #: 668
newton aycliffe (near durham)
min-its had them in when i ordered last month! dont know about now though! Roughly the same price as minispares one!! Might be worth a ring!
