| Home > Help Needed / General Tech Chat > Optimum cooler size | |||||||
![]() 13 Posts Member #: 1310 Member Benson near Oxford |
17th Oct, 2006 at 09:41:09pm
Recently mounted my cooler on top of the front subframe. It basically is as long as the front of the frames bar (not as long as suspension turrets) comes up to the bottom of the dizzy and is about 2 inches wide.
Ok dave, whack it up to a bar......... KABOOM |
17th Oct, 2006 at 10:03:07pm
On 17th of Oct, 2006 at 09:41pm clubman21 said:
*Due to its position and size it will have more cold air hitting it ultimately cool the air more. This however; means that there will be a pressure drop as the air cools and it will require more boost to run. why should there be a pressure drop? if the core looks like it will flow well and there is plenty of air cooling it then it sounds the way to go, an chance of a pic? On 28th Aug, 2011 Kean said:
25 Posts Member #: 1304 Member Ireland |
17th Oct, 2006 at 10:29:47pm
I suppose the pressure would drop as the air becomes more dense as it cools.
Quiet, can you hear it rusting? |
18th Oct, 2006 at 07:32:19am
chris ,
Edited by robert on 18th Oct, 2006. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
18th Oct, 2006 at 10:38:22pm
If you take the wastegate actuator pipe from the plenium instead of from the turbo,The losses will be balanced out
