Home > Help Needed / General Tech Chat > actuator
mickeyturbo
Member #: 1212
braintree, essex
the actuator that comes with the standard t2 from mirage... what psi is it good for or do i ditch it for a bigger one? i only want 8psi for now.
Ask Mirage...
Mirage
Member #: 119
You'll be fine with that actuator, only after 1 bar would i think about swapping it. Remember also that if you use a bleed valve you actuator doses't see the full boost pressure.
