Home > Help Needed / General Tech Chat > Resistance wire to coil
Turbo Tel
Member #: 588
Delaware, USA
Does anyone know where the pink/White wire from the ignition switch to the coil changes from regular wire to resistance wire??
I know I can run a wire from the fusebox instead but if the resistive part is only a few feet long I would rather replace it and rewrap so the loom looks tidyer.... But if its all the way back to the bulkhead its pointless.
shane
Member #: 1246
Lowestoft, Suffolk.
Morning, the ballest resisted wire should come from the ignition switch I believe, hope this helps.
Shane.
fab
Member #: 100
Parisien Turbo Expert
Paris\' suburb
I had to do this conversion on my mini, the resistive wire com from the fuse box, so agree with you , pointless to completely rewrap the loom
fabrice
Turbo Tel
Member #: 588
Delaware, USA
The wire is normal at the plug connection on the steering column so it must change somewhere in the loom. A mate of mine says the MGB resistive wire is about 10 feet long and loops around so I'm not going to chase it, I'll just run a wire from the fusebox. Thanks anyway....
