| Home > Help Needed / General Tech Chat > 998 block with hif 44 metro carb ok?? | |||||||
18 Posts Member #: 1292 Member |
21st Oct, 2006 at 10:08:09pm
I hope this is a new topic, i cannot find anything related to this topic in the search tap.
21st Oct, 2006 at 11:08:58pm
Seems to be what the Hamer's are using
22nd Oct, 2006 at 02:19:17am
can i use the hif 44 in a normal aspirated 998 engine??
22nd Oct, 2006 at 12:39:48pm
Probably a bit much for a NA. A 38 will be better suited. http://www.twin-turbo.co.uk
23rd Oct, 2006 at 04:09:15am
Is it ok to use hif 44 turbo carb in normal aspiration engine??
23rd Oct, 2006 at 08:49:56am
all depends what you want 1 3/4 is a bit big for a 998 unless its a screamer, but works well on a 1098 or 1275 na always looking for them bigger bunches of bannanas |
23rd Oct, 2006 at 04:01:39pm
What if i change the needle to a bigger size, narrowing the orfice of the jet on the hif 44, will it be ok for 998cc??
23rd Oct, 2006 at 05:59:35pm
why not put it on then take it to a rolling road, fit the 38 first and see what power you get, if its faily standard then stick with this.
25th Oct, 2006 at 07:28:40am
i heard 38 is just right from the top to bottom end., 44 is good for torque, but the bottom end is weak, due to lots of air flow though carbs, |
25th Oct, 2006 at 08:05:03am
If it is all you have then stick it on and see how it goes. It sound like that is what you need to do to answer your question. I don't think anybody here has tried it on a NA 998 and we are just advising from our experiance.
