| Home > Help Needed / General Tech Chat > mounting the fuel pump | |||||||
22nd Oct, 2006 at 06:30:55am
I found a fuel filter that also acts as a Tee for the fuel return, mounted the pump and filter under the boot and was feeling pleased with myself until I spotted my exhaust system in the corner of the garage. Completely forgot about that!!! Anyway after moving them a bit The exhaust now fits but do you guys think this will be OK?? I am a bit concerned about the heat from the exhaust affecting the fuel
Edited by Turbo Tel on 22nd Oct, 2006. website:- http://www.terryhunt.co.uk
22nd Oct, 2006 at 07:24:37am
i wrapped my lines in heat reflective tape and its been fine in a similar setup to yours ,although the pipe sits within the u of the subframe .....(last time i tried mounting a fuel pump i got a nasty rash ,and needed 1 and a half stitches ,,, the nurse told me i was trying to use the wrong end) Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
22nd Oct, 2006 at 11:27:54am
I mounted mine internally (in the boot) as I didn’t want the fuel lines / pump to get damaged. |
