| Home > Help Needed / General Tech Chat > Repair patch in Floorpan | |||||||
207 Posts Member #: 193 Senior Member Aylesbury |
22nd Oct, 2006 at 06:31:15pm
I have got to repair a few holes in the floorpan of the metro and was just wondering what thickness metal people would recommend using as a repair patch. Its to cover the hole in the attached picture. Is there a required spec for passing the MOT.
22nd Oct, 2006 at 06:44:44pm
I have some spare floor pieces which i have welded into the car but i need to remove if your interested. You could butcher one to fir that piece! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
22nd Oct, 2006 at 06:48:31pm
Thanks, getting some metal is not a problem for, me i just wasn't sure what thickness to use.
22nd Oct, 2006 at 06:50:48pm
0.8mm is the normal thickness. |
22nd Oct, 2006 at 06:51:19pm
Ok thanks i will look at trying to get some that thickness, thanks. Edited by LukeAnsley on 22nd Oct, 2006. |
22nd Oct, 2006 at 07:03:16pm
MOT requires it is a constant seam of weld all round :) or if it is a complete repair panel that it is weled as-per the origional pannel. turbo 16v k-series 11.9@118.9 :)
22nd Oct, 2006 at 08:45:26pm
And weld the jacking point back on underneath,else that will fail for being in secure
