| Home > Help Needed / General Tech Chat > HELP!!! major misfire and flames | |||||||
17 Posts Member #: 1294 Member Bristol |
24th Oct, 2006 at 07:22:44pm
ok, from the begining:-
24th Oct, 2006 at 07:25:05pm
sorry about the essay, wanted to be thorough.
24th Oct, 2006 at 07:27:41pm
coil. |
24th Oct, 2006 at 07:35:12pm
i thought coil. but does that still sound right considering its almost drivable with the lights off?
![]() 368 Posts Member #: 806 Senior Member Cirencester, Gloucestershire |
24th Oct, 2006 at 07:37:28pm
maybe your fanbelt is loose, so isnt charging the battery enough to give the full voltage to the coil and igntion module Edited by Leonard on 24th Oct, 2006.
24th Oct, 2006 at 11:30:41pm
nah, the fan belt is sufficiently tight, im gonna get a coil tomorrow and see if that sorts it.
Edited by Arun on 24th Oct, 2006. |
24th Oct, 2006 at 11:55:30pm
quick qu. - if i have a flat battery and my headlights don't work, is this cause for concern?
51 Posts Member #: 979 Advanced Member Auckland, New Zealand |
25th Oct, 2006 at 06:22:24am
A flat battery and a alternator thats not charging properly will cause it as i have found in the past. Also the coil will also cause it...and am currently having probs with mine too. 1975 MkIII Morris Mini 1300 Turbo, 100bhp...if only it could run long enough to drive it legally! |
25th Oct, 2006 at 01:35:55pm
When changing your leads did you disturb the wiring loom going to your N/S front light.
Edited by matty on 25th Oct, 2006. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
25th Oct, 2006 at 09:24:13pm
If the coil doesnt sort it, i would go through the front loom and make sure there is no shorting. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
25th Oct, 2006 at 09:38:17pm
in this order ........
25th Oct, 2006 at 10:19:03pm
Also check the engine and battery earth's, cheap fix if thats the prob. |
28th Oct, 2006 at 12:57:15pm
ok, put the battery on charge last night. woke up this morning to find it totally dead.
28th Oct, 2006 at 02:56:40pm
ok, put battery on, but couldnt afford anything else because my paycheque hasnt gone in |
