| Home > Help Needed / General Tech Chat > Minisport Gearbox question | |||||||
314 Posts Member #: 1311 Senior Member Yeovil, Somerset |
24th Oct, 2006 at 08:29:42pm
Currently i have 2 A+ gearboxes. One is a standard metro turbo box (condition unknown) and the second is a reconditioned Minisport A+ gearbox that has only done 500 miles as pictured.
24th Oct, 2006 at 08:35:54pm
Not being funny, but surely the answer is obvious? Use the gearbox that you know has been reconditioned rather than the unknown gearbox. Don't expect it to last forever though, even with only 110bhp.
24th Oct, 2006 at 08:40:09pm
The rebuilt one is the obvious answer but ive heard a lot of negative comments about minisport gear boxes in the past
24th Oct, 2006 at 08:41:32pm
place straight cut drop gears with that box and it will survive 130 ish + bhp for a long while
24th Oct, 2006 at 08:45:43pm
SC drops are on the shopping list but already pushing the budget for this year hence why im only planning on 110 bhp ish this time round
24th Oct, 2006 at 09:12:34pm
On 24th of Oct, 2006 at 08:41pm BENROSS said:
place straight cut drop gears with that box and it will survive 130 ish + bhp for a long while a worth while investment Why would SC drop gears extend the box life ??? I sheared the teeth of uite a few A+ boxes. Always the input shaft and corresponding laygear, and it always happened whilst in 3rd gear. I never had any drop gear issues using the std A+ drops. I even took a couple of teeth of 2nd gear of the Tran-X straight cut box, and the drop gears were always fine. 9.85 @ 145mph
24th Oct, 2006 at 09:17:43pm
Oh, and itf its a used factory metro turbo box....more than likely the bearing on the input shaft will be knackered. 9.85 @ 145mph
24th Oct, 2006 at 09:32:14pm
well i prosume its a standard turbo box, still on the engine at the mo so wont know till the weekend but everything else on the engine is standard so prosume the box will be as well
25th Oct, 2006 at 08:28:56am
I'm not sure that minisport is a good quality shop, and this make me think that they are rebuilding their box with lowcost parts,this said hope I'm wrong.
25th Oct, 2006 at 08:30:37am
suite...( comp hanging)
25th Oct, 2006 at 08:43:55am
Pull the layshaft out the minisport box and check it's been hardend Edited by Dangerous on 25th Oct, 2006.
25th Oct, 2006 at 09:20:09am
How can that casing be so clean after running 500 miles? On 13th Jul, 2012 Ben H said:
25th Oct, 2006 at 09:30:06am
:) karsher! |
25th Oct, 2006 at 10:27:15am
That pic was taken before i built the engine.
