Well i'm selling my engine as a kit comes with everythign you need
New Built Engine
Metro Turbo Block Bored To 1293Cc,
New Omega Pistons,
Standared Turbo Crank,
New Mains,
New Bigends,
Centre Main Strap,
New High Pressure Oil Pump,
Big Vave Head,
Polished Ported,
Broze Guides,
New Double Heavey Duty Valve Springs,
Standared T3 Turbo (has small play in shaft)
New Avonbar 13 Psi Actuator,
New Avonbar Dizzy
New Avonbar Dump Valve (off plenum)
New Avon Bar 10 Psi Carb Needle,New 2"
Rs Turbo Inter Cooler (although not mounted std set up used)
New Hell Oil Cooler With Braded Hoses,
New Grey Diaphram, AP Rally/Race clutch (only had about 50 miles on it)
Recon Turbo Gear Box With Cenre Oil Pick Up,
Duplex Timing Gear,
Standard Turbo Cam,
comes with side rad and fan
silicome hoses throughout
the head gasset did go on it and i did fit a new one but due to me selling it i have taken the head back off so i can take pics for ppl interested.
will come with injection tank, fuel regulator.
only thing needed is down pipe and exhaust
pics will follow.
this is a brand new engine near enough i have replaced nearly all the parts on it that have broken so i dont think there is much more to go wrong with it now. in total of me owning it over 2 years it has covered about 500 miles of general driving usage due to being run in.
spent lots of money on it probably to much, it did smoke a little when come on boost, but the engine has not been RR yet so this could be this or the small play in the turbo?
if you want a brief look at the engine see my thread about my shell for sale and pics in that
the only thing you wont be getting is the 2 core rad but a rad will be supplied and so will an export fan for better airflow.
i'd like to get about 800+ (or around) for it if i can seeing as it practically new. the reason i am sellign is i plan to go 16v next year and need some space and money.
PM me with sensible offers
If you want the shell and engine together this can be done but again PM me an offer.
T
www.twitter.com/lilpinkiy
