Home > General Chat > Limited slip diff a good idea?
Hedgemonkey
Member #: 360
Seems my diff pins are clonking and looks like the box (which I was going to use on my SC engine) is going to need a new diff. The car gets driven hard and I've noticed that going around very tight corners I'm spinning a wheel up which is probably why the pins have worn. I have no problems with a big steering wheel and brute force, but I have to keep my cornering. Bearing in mind the car is running 5" minilites with 032R's.
I was thinking about getting a plate diff. Hoping I can get pot joint outputs as I've sold my hardy spicer stuff.
What are your experiences with the things, how did it alter the way the car went and how did you have to change your driving style.
Personnally I wouldnt have anything other than a Salisbury.
The things are awsome. It pulls you tighter into the bend and gives better traction out of a bend or from a standing start. BUT, beware they do tend to tramline a lot which if youre accellerating hard on a not brilliant road can be scary with 10" wheels.
I wouldnt bother with Quaiffe as it doesnt lock the wheels, you still lose 'go' if one wheel is off the ground.
Do make sure if youre running a Salisbury that you have 0 toe on the front as if one wheel loses traction on a wet manhole cover for example, it will pull you to one side, because the wheels point outward slightly.
Paul
Read this:
http://www.gr8website2.com/calverst/articl...s_available.htm
I've bought the Tran-X one.
Hedgemonkey
Member #: 360
So a good idea then. The Trannex looks like the deal.
Lot of money for a hunch but I think my twin pin is fucked. It's definately clonking and the bearings are fine. I turned a pukka salisbury diff down for £120 which was before I knew if they were worth it. Hopefully it was shagged anyway.
How hard are crownwheels. I would still like to run a 3.2? Wopping one in a lathe isn't a problem but I don't want to bite off more than I can chew. Was maching some drifts out of a halfshaft a while ago and they are seriously hard.
I've also got the Trax-x one, great bit of kit
Been running the Tran-x for about 4 years now. *smiley*
This isn't quite true. The original design of the ATB meat that it only worked with both wheels one the ground generating torque across the diff, with one wheel in the air there was no torque across the diff and tghe free wheel spun.
Modern ATBs have a certain amount of pre-torque built in so you will always have some drive with a wheel in the air.
I have a TranX and its fantastic, but I wouldn't like to use it on the road (I do have the race one though, the road and rally ones might be less severe).
If I was in the market for a road diff, I'd give the quaiff a go.
Wil
Yeah i run the road spec one and it's fine, my mate {Mike} runs the full race item on the road. This is "vicious" to say the least.
Phil. *smiley*
I'd also use quaife for road, but keep with what I have for the track.
